JGJOHN GEORGE28/06/2015
I have a macro with a user form to add custom properties to file. (part and assembly)
It's working as required, but it is adding all property names to the file even if the values are empty.
Below is the code that controls the function
Function UpdateCustomPropsFromControls()
    Dim objControl As Control
    Dim objTextBox As Object
    Dim objControls As Controls
    Set objControls = UserForm1.Controls
    For Each objControl In objControls
        If objControl.Tag <> "" Then
            Set objTextBox = objControl
            ModelDoc.DeleteCustomInfo2 cmbConfigToUpdate.text, objTextBox.Tag
            ModelDoc.AddCustomInfo3 cmbConfigToUpdate.text, objTextBox.Tag, swCustomInfoText, objTextBox.text
    Next
End Function
Can someone please modify this code, so that if a text box is empty or without any value, that property name shouldn't be added to the file properties
Thanks in advance
