Hello, I combined two irregular shaped objects using constraints (Before.png): i) Face from one object to face of the same size of another object. Then, ii) one edge of an object to one edge of another. When I tried to make the joint curve-like using fillet, SW did not fillet as desired (see After.png).
Is there a way to do it? I suppose maybe i need to somehow merge the two object as one and then fillet the joint?
Yes you need to merge them as one body before using fillets.
