Hi, can someone please help me design a part that looks like the one in the attached picture.
The best way I can describe it is if you take a cylinder and remove the front face and replace with this repeating pattern of alternating rungs. Then you also remove the back, top, and bottom of the cylinder. Lastly, there is a spine on the right and left side holding the ends of each rung. All the rungs and spaces between them are equal length.
Thank you very much!
Mike,
I extruded an arc. And then created a sketch for the cut extrude. The sketch is different from what you need but that can be managed.
I would doubt if this is correct as cut on the curve is going straight instead of normal/perpendicular to the surface. So if you need the cut normal/perpendicular to the surface, model this in Sheet metal (again same two features)
