I have a script that goes through a bunch of routines, but the one of interest looks at any extruded plates and recognizes if the material assigned has "GRTG" in the name implying grating and if it does, then it pulls the material name (string) apart to populate the Cut List Properties. This function works really well.
So we identified that we need another function to identify if the material has "EXP METAL" in the name implying expanded metal. If it does, then we want the Cut List Properties populated a certain way.
The material is as follows:
5.00#/SQ FT (CS) EXP METAL
where:
StockSize_Short = 5.00#/SQ FT
Grade = CS
Type = EXP METAL
From this string, the following Cut List Properties would populate:
StockSize = StockSize_Short x SW-3D-Bounding Box Width x SW-3D-Bounding Box Length x Type
Description = Expanded Metal
For reference, my plates, I've been using this string to populate the Stock Size and I want to use this method to populate both the SW-3D-Bounding Box Width & Length (noted above) the same way.
bRet = f.CustomPropertyManager.Add(propname4, proptype, Chr$(34) + "PL" + "SW-3D-Bounding Box Thickness@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34) + "x" + Chr(34) + "SW-3D-Bounding Box Width@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34))
Here's the Grating Code for Reference:
Dim sMaterial As String | |
sMaterial = GetFeatureCustomProp("Material", f) | |
If Not sMaterial = "" Then | |
Dim iP As Integer | |
iP = InStr(1, sMaterial, "GRTG") | |
'If the material is grating then let's change the values | |
If iP > 0 Then | |
ChangeCustomPropForGrating sMaterial, f | |
End If 'End of material being grating if | |
End If 'End of material being blank if |
Sub ChangeCustomPropForGrating(ByVal TheMaterial As String, ByVal TheFeature As SldWorks.Feature)
Dim bRet As Boolean
Dim iGrtg As Integer
Dim iSpace As Integer
Dim sGrade As String
Dim sStockSize As String
Dim sStockSize_Short As String
Dim sType As String
sType = "GRTG"
iGrtg = InStrRev(TheMaterial, sType)
If iGrtg > 0 Then
iSpace = InStr(1, TheMaterial, " ")
sGrade = Left(TheMaterial, iSpace - 1)
sStockSize = sGrade + " " + Trim(Mid(TheMaterial, iSpace, iGrtg - iSpace))
sStockSize_Short = sGrade + " " + Trim(Mid(TheMaterial, iSpace, iGrtg - iSpace))
bRet = TheFeature.CustomPropertyManager.Set2(propname5, sGrade)
bRet = TheFeature.CustomPropertyManager.Set2(propname4, sStockSize)
bRet = TheFeature.CustomPropertyManager.Set2(propname11, sStockSize_Short)
bRet = TheFeature.CustomPropertyManager.Set2(propname3, sType)
bRet = TheFeature.CustomPropertyManager.Set2(propname2, "BAR GRATING")
How can I manipulate this to work as intended. I tried copying and pasting this and modifying, but I can't figure it out.
(Full macro is attached)
Shaun
I figured it out... Combination of things... but this fixed it.
bRet = TheExpMetFeature.CustomPropertyManager.Delete(propname4)
bRet = TheExpMetFeature.CustomPropertyManager.Add(propname4, proptype, Chr$(34) + sStockSize_Short + "x" + Chr$(34) + "SW-3D-Bounding Box Width@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34) + " " + sType + Chr$(34))
