Today's SolidWorks problem is I can't get the pdf to update. I made a pdf, then noticed I didn't fill in the revision. After filling in the revision I saved the drawing, and then saved it as a pdf. The new revision line isn't showing in the pdf. I closed SolidWorks completely, re-opened it, and saved the pdf again. The revision still isn't there.
Be sure to check the location of where you are saving the pdf.
Chris
