How come when I put my cursor over the part or assembly in the design library, it does not show the descpription anymore in 2015?
The attached images are showing a decription underneath the image on a file that has not been saved to the current version (2015) of SW. I noticed that this goes away once the part is save in 2015.
This is a very nice feature, because if you don't know the nomenclature of the part, it is hard to grab the correct one right away without having to spend time to look it up.
When we save the part or assembly in the Design Library, we will fill out the description in the custom properties.
I've looked all over to see if this is an option setting somewhere, but was unable to find it. I don't think this is a Windows issue because this just started happening once we upgraded to 2015 from 2014.
Problem went away with the Solidworks 2017 SP1.0
We found no solutions during 2016 and this was causing headaches for all of our engineers. It is an absolutely unacceptable glitch and cost countless time and money.
