the fillet option adds extra bits to an edge. Is there a command to do the opposite? I want a command to fillet/cut inward at user specified curvature as indicated in pink. Thanks.
You could do an extrude cut using a sketch similar to the pink arc you have shown, or create the extruded block as a seperate solid body (i.e don't merge on creation), add the fillet as required & then combine the two solid bodies after.
Peter,
