Hi
Can I assume that I would not be able to model in sheet metal a PFC section and obtain a flat pattern.
I assume this because for a 300 x 90 x 41 PFC the web is 9mm and the flanges are 15.5mm, so I do not have a constant thickness.
If this is the case has anyone got a work around to obtain the flat?
Mark
(SolidWorks 2015 sp3)
You'll have to manually draw the flat pattern sketch and extrude that.
