I modeled a pipe which carry air. While air passing through pipe, heat transfer take place. Hence, air outlet temperature will be less than air inlet temperature.
Now I want to do take first time outlet air temperature as an input for my next simulation stage... like a closed loop.
In this case “Chris Michalski” replied to me
“Look into goals. Likely a surface goal using the exit lid as the surface. Then you can define your inlet temperature as a function of that exit goal”
So I created surface goal in exit lid. (See the attachment). But I don’t know how to define inlet temperature using this function. Please direct me.
Thank You,
Janitha
