Hi all,
Basically I'm trying to mirror the two extrude cuts about the right plane (See below), however this can't be completed due to a geometric condition. I can't see why as the part is symmetric.
The cut consists of two parts, the first which was partly successful, and the second which cannot be carried out:
I'm sure there must be a simple solution to this, if someone can make this part symmetrical so that all interior channels can be accessed from the outside I would much appreciate it.
Part is attached.
Cheers
I'm sure there is a solution but... I'd suggest you focus only on the 1/2 and mirror at the end.
