3 Replies Latest reply on Oct 9, 2015 5:27 AM by Yong Ning
    Example macro to export dwg with "set custom map file"
    Mario Zahren
      Hello all,
      I need an example to save a SolidWorks-Drawing as a DWG. Therefore it is necessary to use a mappingfile to map SolidWorks drawing entities and colors to layers when saving the drawing.
      Any help would be appreciated.
      Cheers
      Mario
      Here is the code I use so far:
      Option Explicit
          Dim swApp                   As SldWorks.SldWorks
           Dim swModel                 As SldWorks.ModelDoc2
           Dim sPathName               As String
           Dim nErrors                 As Long
           Dim nWarnings               As Long
           Dim nRetval                 As Long
           Dim bShowMap                As Boolean
           Dim bRet                    As Boolean
           Dim CustomerA               As String
           Dim Index                   As Boolean
           Set swModel = swApp.ActiveDoc
           ' Strip off SolidWorks drawing file extension (.slddrw)
           ' and add DXF file extension (.dxf)
           sPathName = swModel.GetPathName
           sPathName = Left(sPathName, Len(sPathName) - 6)
           sPathName = sPathName + "dwg"
           CustomerA = "\\hgntsrv11\Solidworks\Dateipositionen\DXF_DWG_Abbildungsdatei\HME_Abbildungsdatei.txt"
          ' Turn off showing of map
           bShowMap = swApp.GetUserPreferenceToggle(swDXFDontShowMap)
           swApp.SetUserPreferenceToggle swDXFDontShowMap, False
           bRet = swApp.SetUserPreferenceStringValue(swDxfMappingFiles, CustomerA)
                     swApp.SetUserPreferenceStringListValue swDxfMappingFiles, CustomerA
                     Index = swApp.GetUserPreferenceIntegerValue(swDxfMappingFileIndex)
                     If (Index = -1) Then
                     swApp.SetUserPreferenceIntegerValue swDxfMappingFileIndex, 0
           bRet = swModel.SaveAs4(sPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
           If bRet = False Then
               nRetval = swApp.SendMsgToUser2("Problems saving file.", swMbWarning, swMbOk)
          ' Restore showing of map
           swApp.SetUserPreferenceToggle swDXFDontShowMap, bShowMap
      I´m having trouble integrating the map file "CustomerA"
      Can anybody help?
      Mario
