I'm having some trouble with a BOM for an assembly I'm
working on.I have a subassembly in it but for some odd reason it
doesn't showup in my BOM. The PARTS of the subassembly do show up,
however.
Feeling a bit lost because there are a few subassy's that need tohave their parts listed separately. I was able to assign certainparts to not appear in the BOM, and did the same with this onesubassy. The three parts that make up this delinquent are set notto appear in the BOM, I only want the subassy to appear because itsfrom a supplier, not in-house (cadregister and 3Dcontentcentralboth turned up empty looking for it).
Previously, even with the 3 parts allowed to appear in the BOM, thesubassy still was not listed. Any ideas what could be generatingthis wierd omission?
Running 2006 SP 4.1
Running 2006 SP 4.1
Because the parts show but the sub does not, I would look at the Top Level properties of the BOM to see what "BOM Type" it is. My guess would be that it is set to "Parts Only". If this is the case, select "Indented Assemblies"
Beside this, there are only two settings you should need:
For Subs not to show the part, even when an indented bill is being input, go to the sub assembly, then Configuration Properties and check the box for "Don't show child components in BOM when used as sub-assembly".
Other than that, there is a setting for individual parts (in assembly mode) under components properties called "Exclude from bill of materials".
