I know this question has come up many times, but mine is very specific.
I am trying to save a drawing to dxf/dwg, but the scale is coming out EXACTLY THREE times larger.
So if a tank has a 10 ft diameter, the e-drawings measurement shows it as 30 ft.
I have tried all the usual methods and options (scaling, etc.), and it ALWAYS comes out to exactly three times larger.
The funny thing is - this only happens when I try to convert large layouts.
When I convert small parts, the scale is correct.
Also - this only happened after I switched to 2015. I have never had trouble with this scaling before.
Does anybody know what is going on or is having similar problems? Any suggestions? Thanks in advance.
Matthew,
Thank you for that suggestion. I opened my dwg file in Draftsight, and all my dimensions are correct. So it wasn't the export process that was the problem.
The E-Drawings 2015 measuring tool is incorrect......
