Is there a way or setting that allows you to specify how sketches appear in drawings? For example, can I import line settings from the sketch, or specify line appearances in some automatic fashion anywhere?
I don't really have a good answer for your question, but one thing that might work for you is select the sketch from the tree and then convert entities to copy the sketch to your drawing. Then you can change the line style of the converted entities.
