What might the reason be behind me not being able to make these 2 sketched circles "equal"?
Sketch 1 is the sketch that was used to create the pipe extruding out of the block.
Sketch 2 is the pipe I'm trying to extrude off of the pipe elbow.
Why can't I add an "Equal" relation to make my new sketch equal in diameter to the existing sketch?
I've also had problems with setting equal relations between sketch elements from different sketches, especially if they aren't on the same plane. The best I can suggest is to set a global variable equal to the diameter of the circle in sketch 1, and link the dimension in sketch 2 to this global variable. Someone else may have a better idea.
