hello,
RE: SW version = SW 2015 workgroup pdm
the macro below runs a batch save of all the drawings in a particular directory and saves in another directory.
unfortunately, running the macro results in a 'hanging' of SW after some 400 files.
the reason for that is depletion of the number of GDI handles/objects.
under normal circumstances, SW is using 1000 to 1500 GDI handles.
while the macro is running, the number of handles steadily creeps up to approx 9000 after some 400 files; SW becomes sluggish and finally hangs; requiring a restart.
this depletion of resources has been addressed in a blog:
forum.solidworks.com/community/administration/blog/2011/03
under the name: System resources running low ? (a.k.a. GDI handle depletion)
according to the blog however, the issue should have been resolved in a SW 2011 update.
there is of course a second possibility: a coding error in the macro, which I haven't been able to detect.
could someone with similar experiences help me out here ?
many thanks,
Paul
Option Explicit
Dim swExportPDFData As SldWorks.ExportPdfData
Dim boolstatus As Boolean
Dim longstatus As Long
Dim longwarnings As Long
Dim Part As Object
Dim sFileName As String
Dim sModelName As String
Dim sPartName As String
Dim nErrors As Long
Dim nWarnings As Long
Const PathSrc As String = "Z:\solidworks\drawings\"
Const PathTgt As String = "Z:\hotfolder\pdf\"
Const PathJpg As String = "Z:\hotfolder\Thumbnails\"
On Error Resume Next
sFileName = Dir(PathSrc & "*.slddrw")
swExportPDFData.ViewPdfAfterSaving = False
Do Until sFileName = ""
Set swModel = swApp.OpenDoc6(PathSrc & sFileName, swDocDRAWING, swOpenDocOptions_Silent, "", longstatus, longwarnings)
Set swModel = swApp.ActiveDoc
sModelName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
sModelName = PathTgt & Left(sModelName, InStrRev(sModelName, ".") - 1) & ".PDF"
Set swExportPDFData = swApp.GetExportFileData(1)
swModel.ViewZoomtofit2
swModel.ForceRebuild
swModel.Extension.SaveAs(sModelName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, swExportPDFData, nErrors, nWarnings)
If Not swModel Is Nothing Then
swApp.CloseDoc swModel.GetTitle
Set swModel = Nothing
sFileName = Dir
Loop
I can not confirm this that SW does clean up the GDI handles/objects on a regular basis but the macro running in the background should not have any issue as you would be working on active files only. Even when you're working with files, SW doesn't clog up when you've closed the files and working on different one. This give an idea that does clean up the GDI handles/objects on a regular basis.
