Hey guys!
I need help with a feature about drawing. I have made a part with changes dimensions, but the overall form is the same. Therefore I have made a "Design table" with an excel document. I can adjust the specific dimensions in the document and change the part directly.
Now, my question is, can I make a default drawing of the part, with the same dimensions put on the drawing, so that it only changes the magnitude of the dimensions, when I change something in the excel document?
Is the question clear enough?
- Jacob
Jacob,
My guess is that your questions isn't clear.
If you have a design table then all the different configs with different data are stored in there and there for your part will adjust to the data in your design table.
This in turn means that your drawing will adjust to the config you have specified to be used in the drawing.
E.G.: you make a table 1mx2mx0.7m and call it config 1 now when you add config 2 in your design table (1.5mx1.5mx0.7m) all that you have to do in your drawing is click on the views and specify that it needs to depict config 2. Any dimension you put on config 1 will auto adjust to config 2 unless there are feature that have been added or removed between the two configs.
Have a nice one
Peter
