Origins coincident mate through swMateCOORDINATE
Question asked by Leon Wurr on Jun 17, 2015
Latest reply on Jun 18, 2015 by Leon Wurr
Hello
     Has anyone here managed to add a mate via macro by using the type "swMateCOORDINATE" mate?
     My recorded code selects both the origins of the parts I'm trying to mate, but I keep getting error #4 (Incorrect selections for mate) when it tries to add the mate.
     Even if I comment out the lines of the code that select the origins, and select it manually and try to run it, I still get the same error.
     Any ideas of what may be going wrong?
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Point1@Origin@Peça1^Assy1-1@Assy1", "EXTSKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Point1@Origin", "EXTSKETCHPOINT", 0, 0, 0, True, 0, Nothing, 0)
Dim myMate As Object
Set myMate = Part.AddMate5(20, 0, False, 0, 0, 0, 0, 0, 0, 0, 0, False, False, 0, longstatus)  'swMateCOORDINATE = 20
Part.ClearSelection2 True
Part.EditRebuild3
If longstatus <> 1 Then swApp.SendMsgToUser "ERROR #" & longstatus
Thanks!
References:
2015 SOLIDWORKS API Help - AddMate5 Method (IAssemblyDoc)
2015 SOLIDWORKS API Help - swMateAlign_e Enumeration
2015 SOLIDWORKS API Help - swAddMateError_e Enumeration
2015 SOLIDWORKS API Help - swMateType_e Enumeration
