I am not sure if anybody else has had this issue, I can't seem to find a thread about it, but I am working on a detail drawing right now and I am adding a dimension for a corner radius that is within another inner radius. To be able to call out the dimension visibly, I need to break the leader line by adding a jog point so I can pull out the dimension leader line. In this process I am also calling out that this radius is in multiple places.
What the issue is is that when I add a note onto the dimension to call out the radius as multiple places or typical, and then add the jog point in the leader line the arrow disappears. I have also tried adding the jog point in the leader line first, successfully, then I add the note and the arrow disappears still. So I would actually call it a detail issue. Has anybody had this issue as well.
FYI: I am running Solidworks 2015 x64 SP3.0
Thank You.
I do not get the same bug in SW2015 SP5.0. Moreover, even if I manually change the leader style to remove the arrow as soon as I add a jog point it changes back to arrow style. But you could try checking the Leaders tab of the dimension anyway and make sure it is set to arrow style.
