Custom Propertie & Info Not Saved
Question asked by Willie Roelofs on Jun 17, 2015
Latest reply on Jun 18, 2015 by Willie Roelofs
I have a userform with a couple of textboxes.
When the userform is activated all the textboxes will be filled with the currently stored data.
When I edit a textbox, I want to save that information in the correct custom property.
The data however is not saved. I wish to know what I'm doing wrong.
[code]
Dim swApp          As SldWorks.SldWorks
Dim swModel        As ModelDoc2
Dim swModelExt     As SldWorks.ModelDocExtension
Dim swAssy         As SldWorks.AssemblyDoc
Dim swSelMgr       As SldWorks.SelectionMgr
Dim swComp         As SldWorks.Component2
Dim name           As Variant
Dim names          As Variant
Dim textexp        As String
Dim evalval        As String
Dim OmschrijvingGevonden    As Boolean
Dim NabehandelingGevonden   As Boolean
Dim RevisionGevonden   As Boolean
Dim GetekendGevonden   As Boolean
Dim GewijzigdGevonden  As Boolean
Private Sub UserForm_Initialize()
Set swApp = SolidWorks.Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swModelExt = swModel.Extension
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
names = swCustPropMgr.GetNames
For Each name In names
    swCustPropMgr.Get2 name, textexp, evalval
    If name = "Description" Then
        NrSave1.benaming.Text = evalval
        OmschrijvingGevonden = True
    If name = "Nabehandelingofniet" Then
        NrSave1.nabehandeling.Text = evalval
        NabehandelingGevonden = True
    If name = "EIT-Getekend" Then
        NrSave1.getekend.Text = evalval
        GetekendGevonden = True
    If name = "EIT-Revision" Then
        NrSave1.revisie.Text = evalval
        RevisionGevonden = True
Next name
If OmschrijvingGevonden = False Then retval = swModel.AddCustomInfo3("", "EIT-Omschrijving", swCustomInfoText, "")
If NabehandelingGevonden = False Then retval = swModel.AddCustomInfo3("", "Nabehandelingofniet", swCustomInfoText, "")
If GetekendGevonden = False Then retval = swModel.AddCustomInfo3("", "EIT-Getekend", swCustomInfoText, "")
If RevisionGevonden = False Then retval = swModel.AddCustomInfo3("", "EIT-Revision", swCustomInfoText, "")
Private Sub knop4_Click()
swCustPropMgr.Set "Description", benaming.Text
swCustPropMgr.Set "Nabehandelingofniet", nabehandeling.Text
swCustPropMgr.Set "EIT-Getekend", getekend.Text
swCustPropMgr.Set "EIT-Revision", revisie.Text
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("Default")
swCustPropMgr.Set "EIT-Gewijzigd", gewijzigd.Text
[/code]
