Sir, i am trying to analyse a weldement structure in solidworks it is basically a roll cage but the only message i am recieving is "Meshing failed, terminating analysis". I have tried to apply mesh control, use it as a solidbody but no solution found please help
I have attached the part file of the weldement structure (roll cage)
I see a lot of beam interference in your model. If you get rid of the interference it should work. (Try the Trim/Extend feature)
