Hey all-
Everytime I print to PDF, my lineweights always seem to print all the same weight.
This is even after I preview and see that the object lines are much thicker than the dimensions line thickness.
Can anyone help me with this?
Hey all-
Hi Scott Stoltenberg ,
Assuming your line weights are set in the document, there is a setting within the Print command that should help while in a drawing - File> Print. Click on Line Thickness
there are a few posts on this subject - searhc for print line weights or lione thickness CHANGING LINE THICKNESSES Hope it helps
This sounds like it is a setting within the pdf software you are using.
