Hi all, I am having some trouble lofting these profiles so that they stay tangent and the end result is a smooth loft with continuity between surfaces. I created these lofts by making a surface, flexing it so that it bends 180 degrees, and offsetting it. Then I added planes and profiles for my lofts. The bottom portion, where the curve meets the flat section, it stays tangent there. That is a smooth transition.
However, the top, where it goes from the curve to an angled up straight section has a little bump between surfaces. It doesn't meet smoothly. This is pointed at by the arrow. It is strange because in the top view it doesn't bump out on the sides. Only from a side view is the bump visible. It is especially weird because my surfaces I used as guide curves/centerlines for my lofts are smooth and tangent. How can I make this transition between lofts smooth and tangent like the bottom section?
It is hard to say for sure what is going on without seeing the actual part. Can you attach your file here? Here are some things you could check:
1. It may just be a graphics issue and not actual discontinuity in the part. In Document Properties > Image Quality move the slider at the top to a higher setting and see if it helps.
2. Edit the loft feature, right click on one one the profiles and select "Show All Connectors" or something like that. Then make sure the connection dots are in the same place in each profile sketch.
Also I just thought that maybe you can use a sweep instead of a loft if the profile doesn't change shape along the path. You might not even need a guide curve but you could try with and without.
