I have just started trying to figure out how to use weldments and have built my first part. I had to create a few profiles, and when I did I did not set the custom properties right away. I built my structure and went to insert a weldment cut list into the drawing, then realized I needed to set my custom properties. I went back into the profile and set the properties and saved. The custom properties of existing weldments do no show up in the weldment cut list, but if I add a new weldment, then the information shows up. Is there any way of having these custom properites show up for the existing parts without manually updating each one through the cut list in the feature manager?
Thank you,
Colleen
No, there isn't. When you use the Structural Member function the sketch from the .sldlfp file is copied to the part, but doesn't stay linked to it.
