I have a simple part that is apparently ridiculous difficult to convert to sheet metal so I can flatten it, see attached.
Maybe it doesn't have to be sheet metal to flatten?
Anyone want to take a stab at it? and save in SW13 or explain so I can use your work?
Jerry
Ah - missed the 2013 option. Here are the screen captures
First sketch the main profile - I used the Top plane
Then use sheet metal functionality directly extruding up or down, thickness reversed to inside.
Then create your next sketch on the Front Plane
Cut Extrude and make sure it has the "Normal Cut" option checked (normally does with sheet metal). As I did 1 closed profile, I chose also "Flip side to cut", to cut the outside of the sketch profile.
Then I have the finished part (not including the holes - I think you can do that)
Then you can use the Flatten command to see the flattened shape including the bounding box.
Hope that helps.
