How can I rename Cutlist Folders
Question asked by Shaun Jalbert on Jun 12, 2015
Latest reply on Jan 19, 2017 by Arif Akbas
I have a snippit of code that I'm trying to modify but I'm not having any luck. This code finds the file name and renames the cutlist folders to match and adds a sequential instance number after it. Folders looks like:
<filename>-1
<filename>-2
etc..
What I want it to do is look up a custom property called "WLD_MK_NO" instead of the file name, then rename the cutlist folders to match "WLD_MK_NO" and add the sequential instance number after it.
<WLD_MK_NO>-1
<WLD_MK_NO>-2
etc..
How can I achieve this?
Dim swApp As Object
Sub Main()
Dim doc As SldWorks.ModelDoc2: Set doc = swApp.ActiveDoc
Dim partdoc As SldWorks.partdoc: Set partdoc = doc
Dim f As IFeature: Set f = doc.FirstFeature
Dim bRet As Boolean
Dim n As Integer: n = 0
Dim num As String
Dim modDocExt As SldWorks.ModelDocExtension
Dim Part As Object
Dim boolstatus As Boolean
Dim BodyFolder As SldWorks.BodyFolder
Dim BodyCount As Long
Do While Not f Is Nothing
If f.GetTypeName = "CutListFolder" Then
        Set BodyFolder = f.GetSpecificFeature2
        BodyCount = BodyFolder.GetBodyCount
    If BodyCount > 0 Then
        n = n + 1
        If n < 1000 Then
        num = "-" + Right(Str$(n), Len(Str$(n)) - 1)
        If n < 100 Then
        If n < 10 Then
        num = "-0" + Right(Str$(n), Len(Str$(n)) - 1)
If Right(doc.GetTitle, 7) = ".SLDPRT" Or Right(doc.GetTitle, 7) = ".SLDASM" Then
    f.Name = Left(doc.GetTitle, Len(doc.GetTitle) - 7) + num
Else
    f.Name = Left(doc.GetTitle, Len(doc.GetTitle)) + num
