I have one question for today and I hope someone can help me. I have an import model with no features and I want to copy its surface so that I can work on it in SW. Copying surfaces is easy but my question is how do I copy the surfaces and be able to edit the surfaces as if the model is a SW model? Like if I need to change a surface's depth or tweak it if I need to.
Thanks in advance!
KN
If it is a surface body or solid body then it's easy, use the off-set surface tool, set the value to zero, and accept. If it is a .stl file then it's going to take some more work and software which I can't help you with.
