For odd reasons, my add-in gets into a scenario where AddCommandTab fails to return my add-in command tab.
ie following typical add-in samples in C#, I have the following code:
//if cmdTab is null, must be first load (possibly after reset), add the commands to the tabs
if (cmdTab == null)
cmdTab = _commandMgr.AddCommandTab(type, Title);
If _commandMgr is good (i think...how can i tell?) and type is just an swDocumentType_e, then WHY would this call ever fail?
It occurs for me when I've done some messing around with standard cmdTab visibility (essentially hidden all cmdTab's but my add-in tab) and then I have some improper shutdown (like a crash). Under a normal shutdown, I have code that manages the cmdTab visibility and keeps standard UI kosher. But in the case of a crash, I seem to be stuck. My add-in fails to load b/c cmdTab is null after above call.
Did you ever manage to figure this out? I am having the same issue in 2015.
