Global rotating/ Rotating walls-Differente results
Question asked by Linxi Gao on Jun 10, 2015
         I'm modeling a rotating coupling contained in a stationary guard. This is a closed system, no inlet, no oulet, just air in the guard. I want to see at which temperature the air will arrive because of the rotating coupling.
         If I understand well, for my case, to model a rotating component, there are two ways:
          1. Select 'global rotating' in the wizard, and then in the boudary condition, define the guard as a stationary wall.
          2. Select nothing in the wizard, and then in the bondary conditions, define the coupling as a rotating wall
        Normally, I should obtain the same results. But the problem is that, the results I obtained is totally different. I want to know if there is someting wrong with my understanding?
        Thank you in advance for answering me.
Linxi
