I am trying to simulate simple fluid flowthrough pipe. so I model a pipe using solidworks. But when I openit in Flow work , a 3-D Cubical volume is considered forcomputational domain. I have chosen the "internal" optionbut still not able to get rid of the outside volume. Automatic meshis created for the whole cubical volume.
I would appreciate any kind of help.
Robi
Robi
that's a great idea for the next ER! It would be really useful improvement
Regards, Basil
Really... I do not use that toolbar so much so I have missed that button
Regards,Basil.
Bill
Is this because my lids are assembled to the test part incorrectly or because my test components have not been defined correctly??
Thanks in advance!
First off, are you clicking on the inside faces? Also, go to floworks, tools, Check Geometry. Run the check, it should give you a fluid volume greater than 0. If it is zero than chances are that your lids are drawn wrong or you are missing something.
Bill
Regards
