Hi all,
I think this should be easier than how I do it - but maybe that is the only way...?
In the tree, expand the hole feature, find the sketch that defines the placement of the holes, click on it and select the "Edit Sketch Plane"... It is a pain to have to leave the feature to change this and then go back into it. As I type this I think it sounds pretty whiny and lame. But I already typed it, so , maybe I'll learn something - maybe not.
Shouldn't this be accessible in the Hole Property Manager? Is it? Any other way...?
-Nate
As others have said that is the only way. But you shouldn't really need to go back into the hole wizard feature after changing the plane. Just set up the hole the way you want it and then exit and change the sketch plane. One exception might be if you need to see the hole preview to help you set the correct size or depth, then you might need to go back into the feature after changing the plane.
