I am trying to cut a slit through a plate at a 45 degree angle to the flat surface. I have been unable to draw a guide line on the edge of the plate.
Did you try adding an additional sketch with a line that is at the 45 degrees you want and using it in the "direction of extrusion" box? Here's a screen shot:
I've attached my quick model for you to check out too. Hope this helps.
Matt
