Hi there,
When I'm trying to flatten my ellipse models in sheetmetal it won't work. Is there a solution for this problem or is solidworks just not able to unfold or flatten ellipses?
Thanks.
Hi there,
Thanks.
If it's of a solidworks part file it is not possible. If it's of a sheet metal file it is possible.
Thanks and Regards
Venkatesh S
Application Engineer
E G S Computers India Pvt. Ltd.
http://www.egsindia.com | http://www.egs.co.in | http://www.egsindia.blogspot.in
If you develop your sheet metal with a square shape then unfold and cut your shape then refold it will work for you, could you upload the part ?
Hi there John, Thanks for your help.
Sometimes I'm succeeding while flattern ellipses. But while trying with a simple ellipse base flange extrude the feature won't listen. I have the same problem making a swept flange with an ellipse functioning as my guide line. When I try this I get an error that says i only can use lines an regular arcs.
The uploaded part contains the swept flange error.
I'm not sure what you mean by ellipse. I could't find one in your model. John is correct - For your profile you should have one sketch (make sure it has a tangent relation) and get rid of your base flange.
I have attached an assembly file consisting of your file and your file modified laid on top of each other so you can see there is no difference. In the _db file I suppressed your base flange and added a tangent line to the profile. Flattens like it should.
I didn't know that you can't open a SW file with educational. I did originally open it with 2015 and noticed it was an older version. Opened it in 2014 and it did not indicate older version. Samson, only lines and arcs can be use for the profile. If it would work with ellipses and splines it would be wonderful. Oh Well...
Thank you very much Dennis. I'm able to open your solidwork files by the way. To bad that solidworks won't allow us to use an ellipse sketch as a guideline or profile. I want to use my ellipse sketch for my path. It's kind of hard thought to make the ellipse existing out of single arc lines. Could you maybe upload your last file, so I can check out your arc (ellipse) sketches? Thanks for helping me out.
I think this is going to be a problem for me. I can't get my series of arc lines that exact that I can call it an ellipse. Maybe someone has a solution for this.
You can use an ellipse and make it a construction line and the draw straight lines that somewhat follow the ellipse then add a large enough radius so you don't see the straight lines.
Follow what Dennis did
On the attached file I sketched the ellipse then made it construction. Started with a 3 point arc coincident at 3 points with the construction geometry ellipse. Then used tangent arcs from there. You just sketch the arcs and drag the end around until you get an almost perfect match with your ellipse, accept that and start another tangent arc. This is fairly easy and as you see it becomes an almost perfect match to your ellipse. Also by changing the size of the ellipse your arcs will change with it.
You can sketch a series of tangent arcs around an ellipse. I'm not sure if you want the profile or the path to be elliptical, or, maybe both.
