Performance Issue with Solidworks
Question asked by Prashant Mohan on Jun 3, 2015
Latest reply on Jun 4, 2015 by Prashant Mohan
Hello Everyone,
  I have a macro that creates a sketch containing points (essential having position). It then inserts parts into that sketch to mate with those points. One part is opened and is inserted again and again. Now this works all fine till you have about 200-300 points. However the moment you go above 500 points macro slows down and keeps slowing down. I tried to look for optimizing the performance but was not very successful with it. These parts can be considered as sticks (cylindrical sticks -about 3 mm long) with pointed ends. These pointed ends and plane of the part are used for mating with points on the sketch. I am pasting the code below.  I would highly appreciate any help on this subject.
    Set Part = swApp.OpenDoc6(pathprobe, 1, 0, "", longstatus, longwarnings)
    Set Part = swApp.ActivateDoc2("ORIGIN-DUT.SLDASM", False, longstatus)
    'Set swApp = Application.SldWorks 'yyy
    bRet = swApp.GetUserProgressBar(Progress)
    Dim firstprobe As Boolean
    Dim SketchPntArray As Variant
    Dim ActiveSketch As Object
    Dim ThisSketchpoint As Object
    Dim res As Boolean
    'Set Part = swApp.ActiveDoc 'yyy
    Set SelMgr = Part.SelectionManager
    retval = Part.SelectByID("Sketch1", "SKETCH", 0, 0, 0)
    Part.EditSketch
    Set ActiveSketch = Part.GetActiveSketch2()
    SketchPntArray = ActiveSketch.GetSketchPoints()
    Part.ActiveView.FrameState = 1
    void = Part.SetDisplayWhenAdded(False)
    Part.SetPickMode
    Part.ClearSelection
    Part.Insertsketch
bRet = Progress.Start(0, numofpoint, "Mounting Probes")
For i = 1 To numofpoint
        If menu_broches = 1 Or (menu_broches = 2 And (i Mod Numorigin) = 1) Then    'Or (O(i) = 2 And menu_broches = 3)
            Set Components = Part.AddComponent2(probenames & ".SLDPRT", 0, 0, 0)
            SW_Name(i) = Components.Name
            If O(i) = 2 Or O(i) = 1 Then
                '***********Set red color for rotated pins***********************************
                'Set SelMgr = Part.SelectionManager
                'boolstatus = Part.Extension.SelectByID2("771-001110-xx-7@ORIGIN-DUT", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
                'Dim Component As Object
                'Set Component = Part.SelectionManager.GetSelectedObjectsComponent(1)
                Components.MaterialPropertyValues = vMatProp
                boolstatus = Part.EditRebuild3
            If firstprobe = True Then
                selid = SW_Name(i) & "@" & Assem
                If Not (Part.SelectByID(selid, "COMPONENT", 0, 0, 0)) Then
                    MsgBox "Unable to Select First probe.: " & selid, vbCritical + vbOKOnly, ".: Error :."
                Part.UnfixComponent
                Part.ClearSelection
                firstprobe = False
            selid = "Point1@Origin@" & SW_Name(i) & "@" & Assem
            '====================Get Probe's ID===============================================
            If Not (Part.SelectByID(selid, "EXTSKETCHPOINT", 0, 0, 0)) Then
                MsgBox "Unable to Select tip of probe model.: " & selid, vbCritical + vbOKOnly, ".: Error :."
            Set ThisSketchpoint = SketchPntArray(SketchPointID(i))
            Debug.Print "    Array Values                      = " & SketchPntArray(SketchPointID(i))
            TextBox1.Text = ThisSketchpoint.Value
            If ThisSketchpoint.Select(True) = False Then
                MsgBox "Unable to Select sketchpoint. " & SketchPointID(i), vbCritical + vbOKOnly, ".: Error :."
            '=================Mate probe and Sketch===============================================
            Part.AddMate swMateCOINCIDENT, swMateAlignALIGNED, 0, 0, 0
            Part.ClearSelection
            'Mates plane with point
            selid = "TOP@" & SW_Name(i) & "@" & Assem
            res = Part.SelectByID(selid, "PLANE", 0, 0, 0)
            res = Part.AndSelectByID(vplane, "PLANE", 0, 0, 0) ' for file format of SW 2006
            res = Part.AddMate(swMateCOINCIDENT, swMateAlignALIGNED, 0, 0, 0)
            'Part.HideComponent2
            Part.ClearSelection
            '================Mates finished=========================================================
            XForm = Components.GetXform
            dblTheetaCompZ = -1 * (Ang(i) * DegToRad)
            'Take care of negative angles which do exist in some eng files !@#$%^!
            If dblTheetaCompZ < 0 Then
                dblTheetaCompZ = dblTheetaCompZ + (Pi * 2)
            Select Case dblTheetaCompZ
            Case 0 To (Pi / 2)
                'the coords are in quadrant 1
                NewXForm(0) = Cos(dblTheetaCompZ)
                NewXForm(1) = 0
                NewXForm(2) = Sin(dblTheetaCompZ)
                'Y Vector
                NewXForm(3) = -Sin(dblTheetaCompZ)
                NewXForm(4) = 0
                NewXForm(5) = Cos(dblTheetaCompZ)
            Case (Pi / 2) To Pi
                'the coords are in quadrant 2
                NewXForm(1) = 0
                'Y Vector
                NewXForm(4) = 0
            Case Pi To (Pi * 3 / 2)
                'the coords are in quadrant 3
                NewXForm(1) = 0
                'Y Vector
                NewXForm(4) = 0
            Case Is > (Pi * 3 / 2)
                'the coords are in quadrant 4
                NewXForm(1) = 0
                'Y Vector
                NewXForm(4) = 0
            Case Else
                swApp.SendMsgToUser2 strErrorMsg, swMbInformation, swMbOk
            End Select
            NewXForm(6) = 0
            NewXForm(7) = 0
            NewXForm(8) = 1
            'Translation
            NewXForm(9) = XForm(9)      'no translation
            NewXForm(10) = XForm(10)    'no translation
            NewXForm(11) = XForm(11)    'no translation
            'Not sure what these are
            NewXForm(12) = 1
            NewXForm(13) = 0
            NewXForm(14) = 0
            NewXForm(15) = 0
            XForm = NewXForm
            Call Components.SetXform((XForm))
            res = Components.SetSuppression(swComponentSuppressed)               'Suppress the components to increase speed
            Set Components = Nothing
'        Xuo(i) = X(i)
'        Yuo(i) = Y(i) + dt_low_up
        'nvdat27July09
        Xuo(i) = X(i) - dt_low_up * Sin(Ang(i) * DegToRad)
        Yuo(i) = Y(i) + dt_low_up * Cos(Ang(i) * DegToRad)
        Status = 100 * (i / numofpoint)
'        ProgressBar1.Value = Status
        Frm.Caption = "Mounting..." & Round(Status, 0) & " %"
        Progress.UpdateProgress
    Next
    Progress.End
