I need to make a transition sheetmetal part. When I try to create the loft I get errors that the bend radius is too large. I haven't done many of these. Any ideas?
Tom
Tom
You need to get rid of any points, the profile needs to be smooth, either as a straight line, constant radius or line segments with fillets where they join, what I did was added a circle on top of your sketch and made your sketch line a construction line. Sketch 1 appears to have a scallop and the only way I know is to add them in the flat pattern.
Thanks John,
I used your advice to remove the points. What I did was create 2 new 3d sketches referencing the existing 3d sketches and used a spline. This seemed to work and I was able to use the lofted bend tool and create an unfoldable sheet metal part. This should work well.
Thanks for the input!!
