For historical purposes, there is an older thread on this topic located here: Re: Using variable in task output path S-061104
Unfortunately S-061104 is missing from the SWX knowledge base, but it's title reflects what I'm trying to achieve: placing variable values from source file into output path of a file conversion task. I used the thread listed above in conjunction with S-054527 and S-062476 to try and achieve what S-061104 was aiming to document.
I'm attempting to make PartNo (Part Number), xRev (Revision), and Description (Description) available but the only variable that I can pull is Description. I have a difficult time understanding why Description works but the other two do not. S-061104.docx contains my entire task conversion script with additions highlighted; those sections pasted below for convenience.
Placing "MsgBox Value" below "GetVariableValue = Value" only produces a result for Description. I get nothing, not even an empty dialog box, for PartNo and xRev.
Dim vault As Object
Private Sub LoginToVault()
On Error GoTo ErrHand
Dim strTempVaultName As String
Dim strVaultName As String
strTempVaultName = "<VaultPath>"
i = Len(strTempVaultName)
j = InStrRev(strTempVaultName, "\")
strVaultName = Right(strTempVaultName, i - j)
Set vault = CreateObject("ConisioLib.EdmVault")
vault.LoginAuto strVaultName, 0
Exit Sub
ErrHand:
If Not vault Is Nothing Then
Dim errname As String
Dim errdesc As String
vault.GetErrorString Err.Number, errname, errdesc
Log ("LoginToVault error" & vbCrLf & errname & vbCrLf & errdesc )
Else
Log "Error creating file vault interface."
Private Function GetVariableValue(FilePath, VariableName, Configuration)
Dim File As Object
'Get the interface of the file (and its parent folder)
Dim Folder As Object
Set File = vault.GetFileFromPath(FilePath, Folder)
'Obtain the variable interface
Dim pEnumVar As Object
Set pEnumVar = File.GetEnumeratorVariable
Dim Value As Variant
If pEnumVar.GetVar(VariableName, Configuration, Value) Then
MsgBox Value
Else
GetVariableValue = ""
Exit Function
ErrHand:
Dim ename As String
Dim edesc As String
vault.GetErrorString Err.Number, ename, edesc
Log "GetvariableValue error" & vbCrLf & ename & vbCrLf & errdesc
End Function
'Get the vault interface
Call LoginToVault
'Get Variable Values
Dim PartNumberVarValue
Dim RevNumberVarValue
Dim DescriptionVarValue
PartNumberVarValue = GetVariableValue(docFileName, "PartNo", "@")
RevNumberVarValue = GetVariableValue(docFileName, "xRev", "@")
DescriptionVarValue = GetVariableValue(docFileName, "Description", "@")
convFileName = Replace(convFileName, "<PartNumber>", PartNumberVarValue)
convFileName = Replace(convFileName, "<RevNumber>", RevNumberVarValue)
convFileName = Replace(convFileName, "<Description>", DescriptionVarValue)
convFileName2 = Replace(convFileName2, "<PartNumber>", PartNumberVarValue)
convFileName2 = Replace(convFileName2, "<RevNumber>", RevNumberVarValue)
convFileName2 = Replace(convFileName2, "<Description>", DescriptionVarValue)
For Reference:
S-054527 – ‘How to modify convert task to use variable value from source file in output file name’
S-061104 – ‘How to modify convert task to use variable value from source file in folder name of output path’
S-062476 – ‘ How to modify convert task to use user name in folder name of output path?’
It would seem that the variables of interest have to be expressed according to how they are listed in EPDM's variable list rather than how they're identified in the solidworks file's custom properties.
Making this change seems to be giving me the results I'm looking for.
