As you can see when I make dimensions it gives me radius option. But I want to see it in diameter. Is there any option for this as default?
Hi Ama,
You can perform this by choosing the Leader Style for the Dimension. To do So:
1.Draw a Arc Or Circle
2.Go for Smart Dimension and select the Arc or circle.
3.Then Go to Leaders option and select the Desired One. FYR,I have attached the screenshot.
Thanks & Regards ,
N.Vignesh
