Component selection from design tree
Question asked by John Alexander on Jun 1, 2015
Latest reply on Aug 13, 2015 by John Alexander
Hey guys, just wondering if anyone has a suggestion here. This subroutine grabs an array of the currently selected components in an assembly drawing. The problem I am having is in the section highlighted red below. When a component is selected in the design tree, the macro throws a type mismatch error at the red highlighted line. This means that the type is swSelCOMPONENTS but the selection manager isn't returning a Component2 type object. Any feedback is appreciated.
Sub getSelectedComponentInAssemblyDrawing(swSelectedComponents() As Component2, swSelectedEntities() As Entity)
    'Grabs the currently selected components in an assembly drawing
    Dim swSelectedFeature           As IFeature
    Dim swSelectedEntity            As SldWorks.Entity
    Dim swSelectedComponent         As SldWorks.IComponent2
    Dim swSelectedFace              As IFace2
    Dim swSelectedEdge              As Edge
    Dim swSelectedBody              As Body2
    Dim swSelectedVertex            As Vertex
    Dim numselections               As Integer
    Dim selection                   As Integer
    Dim numComponents               As Integer
    Dim i                           As Integer
    Dim j                           As Integer
    Dim flagValid                   As Boolean
    Dim BomNameCandidate            As String
    Dim BomNameList()               As String
    numComponents = 0
    ReDim swSelectedComponents(numComponents)
    ReDim swSelectedEntities(numComponents)
    ReDim BomNameList(0)
    BomNameList(0) = ""
    numselections = swSelectionMgr.GetSelectedObjectCount
    For i = 0 To numselections
        flagValid = False
        selection = swSelectionMgr.GetSelectedObjectType3(i, -1)
        Select Case swSelectionMgr.GetSelectedObjectType3(i, -1)
            Case swSelectType_e.swSelCOMPONENTS
                Set swSelectedComponent = swSelectionMgr.GetSelectedObject6(i, -1)
                Set swSelectedEntity = Nothing
                flagValid = True
            Case swSelectType_e.swSelVERTICES
                Set swSelectedVertex = swSelectionMgr.GetSelectedObject6(i, -1)
                If Not (swSelectedVertex Is Nothing) Then
                    Set swSelectedEntity = swSelectedVertex
                    Set swSelectedComponent = swSelectedEntity.getComponent
                    flagValid = True
            Case swSelectType_e.swSelEDGES
                Set swSelectedEdge = swSelectionMgr.GetSelectedObject6(i, -1)
                If Not (swSelectedEdge Is Nothing) Then
                    Set swSelectedEntity = swSelectedEdge
                    flagValid = True
            Case swSelectType_e.swSelFACES
                Set swSelectedFace = swSelectionMgr.GetSelectedObject6(i, -1)
                If Not (swSelectedFace Is Nothing) Then
                    Set swSelectedFeature = swSelectedFace.IGetFeature
                    Debug.Assert (Not (swSelectedFace Is Nothing))
                    Debug.Assert (Not (swSelectedFeature Is Nothing))
                    Set swSelectedEntity = swSelectedFeature
                    flagValid = True
        End Select
        If Not (swSelectedComponent Is Nothing) Then
            If flagValid Then
                Set swSelectedComponent = findTop(swSelectedComponent) 'Find the top level parent of the selected component in the drawing assembly
                BomNameCandidate = getBomPartNumber(swSelectedComponent)
                For j = 0 To (numComponents)
                    If (StrComp(BomNameList(j), BomNameCandidate) = 0) Then
                        'Compare the current component to every component in the selected components list, flag false for duplicates
                        flagValid = False
                        Exit For
                Next j
                If flagValid Then
                    numComponents = numComponents + 1
                    ReDim Preserve swSelectedComponents(numComponents)
                    ReDim Preserve swSelectedEntities(numComponents)
                    ReDim Preserve BomNameList(numComponents)
                    BomNameList(numComponents - 1) = BomNameCandidate
                    Set swSelectedComponents(numComponents - 1) = swSelectedComponent
                    Set swSelectedEntities(numComponents - 1) = swSelectedEntity
    Next i
Thank you,
John
