I need to render a video in SolidWorks but it has to have a clear/no background so that it can be put over an image afterwards. How can I do this in SolidWorks 2014 and PhotoView 360?
You could probably render with a bright green or blue or some other color background and use video editing software to remove it, same as with a green screen. Or you could stick the image into the back of the animation itself. If you need it a flat image perpendicular to the view you could insert a flat sheet part in the proper position and stick the image on it as a decal.
The easiest method is to go to the "Edit Scene" options and under background select none.
When you render the frames it will have an alpha channel with the empty background built in. No extra fumbling necessary. The blue screen method is OK, but will get weird with lighting and other features.
