4 Replies Latest reply on Jan 14, 2008 3:27 PM by Vince Adams
    Selecting exposed faces
    Kevin Spradley
      All, I have two plates of material A and material B.  Plate 1is larger (longer and wider) than plate 2.  Plate 2 ispositioned on top of plate 1 such that only a portion of plate 1 isvisible.  I need to apply a load/restraint (heat fluxincident) to the exposed area of plate 1.  Currently when Iselect that area, the whole face is selected which is not a truemodel of the real world.  The flux incident will only hit theexposed faces and the covered area will be heated by conduction. I have not attached the model, but I have attached a ppt fileillustrating what I am trying to do.
      thank you,
      Kevin
        • Selecting exposed faces
          David Arthur
          You can apply a Split Line feature to split the face of plate 1 into exposed area and unexposed area. Then you can apply the heat flux just to the exposed portion of the plate. Split line feature is on curves menu.
              James Huber
              split a cylindrical face?
              I need to apply a load only to a portion of the inside of a cylindrical body. I have tried to use the Insert>Curve>SplitLine method but I can only get it to work on a planar surface (I drew a circle of equal radius on a reference plane). I get the message that it does not intersect the face--I think its projecting along the axis.
              Can anyone help? how do you split the inside face of a solid body cylinder?
