We solved the problem like this:
Set myView = Part.CreateDrawViewFromModelView3(PartPath, "*Front", 0, 0, 0)
Set Part = myView.ReferencedDocument
Dim Bodies(0) As Object
nbrBodies = myView.GetBodiesCount
arrbody = Part.GetBodies2(swSolidBody, True)
swApp.ActivateDoc2 mysheet, False, longstatus
Set Part = swApp.ActiveDoc
i = 0
For Each ding In arrbody
test = ding.name
If test = "Base-Flange1" Then
If (nbrBodies = 1) Then
myView.Bodies = (arrbody)
Else
' Set the body to view
Set Bodies(0) = arrbody(i)
arrBodiesIn = Bodies
myView.Bodies = arrBodiesIn
longstatus = Part.SaveAs3(SavePath & Flange1 & ".DXF", 0, 0)
If Strings.Left(Flange1, 2) = "PA" Then
Flange1 = "GL" + Strings.Right(Flange1, Len(Flange1) - 2)
If test = "Base-Flange2" Then
Else
longstatus = Part.SaveAs3(SavePath & Flange2 & ".DXF", 0, 0)
If Strings.Left(Flange2, 2) = "PA" Then
Flange2 = "GL" + Strings.Right(Flange2, Len(Flange2) - 2)
If test = "Base-Flange3" Then
Else
longstatus = Part.SaveAs3(SavePath & Flange3 & ".DXF", 0, 0)
If Strings.Left(Flange3, 2) = "PA" Then
Flange3 = "GL" + Strings.Right(Flange3, Len(Flange3) - 2)
i = i + 1
Next ding
Does not anybody know?
is anyone there?
replied
