Set the foreshortened Radius  with API
Question asked by Yong Ning on May 29, 2015
How to foreshortened (broken)  dimension. and  move centerpoint of a radius
How to set the Radial Dimension Text Position? | SOLIDWORKS Forums
https://forum.solidworks.com/message/429020#429020
Private Sub ll()
   Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
      Set SwApp = Application.SldWorks
      Set SwModel = SwApp.ActiveDoc
   Dim SwSelMgr As SelectionMgr
      Set SwSelMgr = SwModel.SelectionManager
   Dim SwDispDim As DisplayDimension
      Set SwDispDim = SwSelMgr.GetSelectedObject5(1)
      Debug.Print SwDispDim.ShortenedRadius
      With SwDispDim
         .ShortenedRadius = False
         .ShortenedRadius = True
         Debug.Print .GetBrokenLeader2
         .SetBrokenLeader2 False, swBrokenLeaderHorizontalText
         '.SetBrokenLeader2 False, swSolidLeaderAlignedText
         '.SetBrokenLeader2 False, swBrokenLeaderAlignedText
         Debug.Print .GetPrimaryPrecision2
         .SetPrecision2 0, 0, 0, 0
         Debug.Print .Type2
      End With
      Stop
type2
swDimensionType_e
swDimensionTypeUnknown - Dimension type could not be determined
swOrdinateDimension - Base ordinate and its subordinates are of this type
swLinearDimension - Linear dimension type
swAngularDimension - Angular dimension type
swArcLengthDimension - Arc length dimension type
swRadialDimension - Radial and diametric dimensions are of this type
swDiameterDimension
swHorOrdinateDimension - Horizontal ordinate dimension
swVertOrdinateDimension - Vertical ordinate dimension
swZAxisDimension
swChamferDimension
swHorLinearDimension - Horizontal linear dimension
swVertLinearDimension - Vertical linear dimension
swScalarDimension
Private Sub ll1()
   Dim SwDraw As DrawingDoc, SwSheet As Sheet, vSheet
      Set SwDraw = SwModel
   Dim SwView As View
      vSheet = SwDraw.GetSheetNames
      For ii = 0 To UBound(vSheet)
         With SwDraw
            .ActivateSheet vSheet(ii)
            Set SwSheet = .GetCurrentSheet
            Set SwView = SwDraw.GetFirstView
            Set SwView = SwView.GetNextView
            Set SwDispDim = SwView.GetFirstDisplayDimension
            Do While Not SwDispDim Is Nothing
               If SwDispDim.Type2 = swRadialDimension Then
                  With SwDispDim
                     Debug.Print .Type2
                  End With
               SwDispDim.SetPrecision2 0, 0, 0, 0
               Set SwDispDim = SwDispDim.GetNext
            Loop
         End With
      Next ii
Function AlignDimCen(SwView As View)
    Dim SwDim As Dimension
    Dim SwAnn As Annotation
       'Debug.Print SwView.GetName2
       If SwView Is Nothing Then
          Exit Function
          With SwDispDim
             Set SwDim = .GetDimension
             If .GetType = 5 Then
                .CenterText = True
                .BrokenLeader = False
                If SwDim.FullName Like "*Dn*" Then
                   .SetBrokenLeader2 False, swDisplayDimensionLeaderText_e.swBrokenLeaderAlignedText
                Else
                   .SetBrokenLeader2 False, swDisplayDimensionLeaderText_e.swBrokenLeaderHorizontalText
             ElseIf .GetType = 2 Then
                .CenterText = True
                .BrokenLeader = True
             Else
                .CenterText = False
                .SetBrokenLeader2 False, swDisplayDimensionLeaderText_e.swSolidLeaderAlignedText
             .SetDual True
             .ShowParenthesis = False
             Set SwAnn = .GetAnnotation
             SwAnn.Layer = "尺寸线"
             Set SwDispDim = .GetNext
          End With
       Loop
End Function
Private Sub ll3()
   Dim vSheets, SwSheet As Sheet, SwView As View
      vSheets = SwDraw.GetSheetNames
      For ii = 0 To UBound(vSheets)
         SwDraw.ActivateSheet vSheets(ii)
         Set SwSheet = SwDraw.GetCurrentSheet
         Do While Not SwView Is Nothing
            AlignDimCen SwView
         Loop
      Next ii
