When changing states, we are asked to enter in comments. I'd like to like what is typed into a data card variable.
You can link a control on a data card to the last version or transition comment:
Jim S.
Hey Elmer,
If you just want to see the comment use Jim's solution, but if you need it written to a variable (not sure why you would unless it's a revision table thing or something) you can do that as a transition action:
Using that transition comment as a revision description to add to the engineering change database. So this is perfect. Thanks.
Hey Elmer,
