Alrighty, a good place to start would be to detail some
background before describing the problem. I will also go into the
details that probably aided this problem.
Background
All the toolbox parts what we use have three custom properties (CPs) that we created. There is Our P/N, Manuf. P/N, and Description. We've been using these custom properties for about 2 years without much problem. We're using SolidWorks 2007 Professional.
The Culprit?
I updated us to SP4.0 (SW2007) from SP3.0 or SP3.1. I was thrilled to find that this erased all files on my server's root folder. Several days later my engineers informed me that the toolbox was messed up. I checked the custom properties of several specific parts (after rolling my eyes of course) and discovered that they were correct, something fishy was up with our toolbox!
Problem
I had previously mentioned that we have 3 CPs for each configuration that we use. Now for some parts we only had two; "Description" was missing completely. Furthermore, some of my CPs had changed to the CPs of other parts. For example, my 0.25" regular lock washer lists the P/N and Manuf. P/N of my 0.5" regular lock washer. Description was still missing, of course.
Plea
Anyone who has seen similar funked behavior please let me know how you fixed it! I'd rather gnaw my arm off before telling my engineers they have to redo all these CPs, which would result in me watching them gnaw their arms off to avoid doing the same thing twice.
Thanks!
The Mex
Background
The Culprit?
Problem
Plea
Thanks!
The Mex
We also have 3 cp's, material, description & part number. Ihave also found some of the parts list the cp's twice whenselecting from the available configurations. I also had this samething happen before and found the database to be corrupt. Myreseller could not repair it so I had to recreate the whole thing.ARGGGG!
I put in an enhancement request on this problem. If SW cannotsupport this database properly then it should be removed! I am nowlooking for a third party solution.
Wish you luck. I'm on the third re-creation!
