We have a macro that sends a .DXF of the flat pattern to our laser so I know the embossing cannot be present on this. So a new configuration without the embossing would be needed. But I would like to be able to show the embossing on the flat pattern as well as the rolled config. without "fudging" it on the drawing. I've attached the part I'm trying to do this on as well as the DWG explaining the emboss needed.
Thanks for any help!
Ok Brian,, I have attached a 2014 version of my file. The file is an assembly which includes your file and my file (made from yours) on top of each other so you can see the differences. This came out much better than the first file I sent. I simplified my emboss tool which seems to allow the flex feature to work as expected. The radius is the same but the strips and cut up the side do not line up exactly. I believe the reason for this is the flex feature does not take into account any stretching and compressing which the sheet metal fold and unfold does. Open my file from this assembly and check out the configurations.
