Hi!
I'm new to Solidworks and I'm trying to figure out what the square brackets in the FeatureManager Design Tree mean.
I have found the float and fix-settings of parts within an assembly, but i just can't find information about the brackets. Sometimes i get fixed or floating parts with brackets around their names, sometimes fully defined parts gets brackets around the names, and sometimes i just don't get brackets at all. Does the brackets have something to do with the mates (or lack of mates) or am i searching the wrong area?
In the attached photo all parts have brackets around their names exept the fourth part (sidoväggar).
Thanks for help!!
Hilda
Virtual part. Part that only exists in the assembly, not as a file outside it.
If you want to create files when you make a new part by default you can change it in options
You can also rmc on it and select "save in external file" if you want to have it as separate file.
