BSBill Schmid27/05/2015
I'd like to add leader notes to a drawing that identify sub-assemblies in an assembly.  Rather than type the part number and description in each note, I'd like it to pull that from custom properties in the sub-assemblies.  If I could set this up right, it would be faster and less error-prone.
But, SolidWorks won't link to properties of a sub-assembly.  The Link to Property dialog box allows me to link to:
- Current document
- Model in view to which the annotation is attached
- Model in view specified in sheet properties
- Component to which the annotation is attached
Can I make SolidWorks (2013, in this case) ignore the components of a sub-assembly, or make it only go 1 level deep, or configure the sub-assembly so its components are ignored wherever it's used?
Adding to the frustration, I had done this in Inventor which lets you identify assemblies as phantom or purchased so you can control what gets linked to or looked at in a drawing.
