Dose any one know if you can have one section inside another all at the same time this is for UPVC windows with a steel section inside the UPVc section
do you also know if you can have custom properties for the Upvc & the steel at the same time their is also a rubber seal
i can make a standard Steel tube or channel but this is a little more complicated
or is it two sections that follow the same path?
Thanks Andrew
You can have only section type in one feature. But you can add additional features with different sections and use the same path.
Hope this is what you had been looking for.
