Weldment BOM - Plate vs. Grating
Question asked by Shaun Jalbert on May 26, 2015
Latest reply on Jun 15, 2015 by Adam Hoffman
When we create our grating for work platforms, etc., we model it as an extruded plate feature with no details. Of course, this throws off the weight, so I've combated this by adding a material in our database that corrects the mass by fudging a density so that the weight per square foot matches real life. this all works OK, but here's where my problem is...
I run a macro (shown below) that does several things.
1) it renames the weldment folders
2) Creates a bounding box
3) Adds a mass (for BOM)
4) Adds a type (for BOM)
5) Determines if a member is a plate or bent sheet metal (for BOM)
  5a) Modifies the Stock Size
  5b) Adds the Length
  5c) Modifies the description to suit
My issue is that this macro identifies my grating as a plate and my BOM populates with plate.
I didn't create the macro, I've only modified it to suit so i don't know if this is even possible, but is it possible to add a lookup function on the plate material and if it matches "W19-4 1 1/2" x 3/16" GRTG" to populate the properties as such:
Grade= W19-4
Stocksize=  1 1/2" x 3/16"
Length= (as per bounding box)
Type= GRTG
Description= Grating
My concern is that the grating material name could vary according to size (ex. W19-4 1” x 1/8” GRTG, or SP19-2 2 1/2” x 3/16” GRTG).
Any suggestions on how to modify this code to suit?
Option Explicit
Private Const propname1 As String = "Mass" ' change to "MASS" or whatever you prefer
Private Const propname2 As String = "Description"
Private Const propname3 As String = "Type"
Private Const propname4 As String = "StockSize"
Private Const propname5 As String = "Grade"
Private Const propname6 As String = "Length"
Private Const propname7 As String = "Mark"
Private Const propname8 As String = "PARTNUMBER"
Private Const propname9 As String = "Sheet Metal Thickness"
Private Const propname10 As String = "ANGLE1"
Private Const proptype As String = "Text" ' in english you must change to "Text". See comment in code…
Dim swApp As Object
Sub Main()
Dim doc As SldWorks.ModelDoc2: Set doc = swApp.ActiveDoc
Dim partdoc As SldWorks.partdoc: Set partdoc = doc
Dim f As IFeature: Set f = doc.FirstFeature
Dim bRet As Boolean
Dim n As Integer: n = 0
Dim num As String
Dim modDocExt As SldWorks.ModelDocExtension
Dim Part As Object
Dim boolstatus As Boolean
Dim BodyFolder As SldWorks.BodyFolder
Dim BodyCount As Long
Do While Not f Is Nothing
If f.GetTypeName = "CutListFolder" Then
        Set BodyFolder = f.GetSpecificFeature2
        BodyCount = BodyFolder.GetBodyCount
    If BodyCount > 0 Then
        n = n + 1
        If n < 1000 Then
        num = "-" + Right(Str$(n), Len(Str$(n)) - 1)
        If n < 100 Then
        If n < 10 Then
        num = "-0" + Right(Str$(n), Len(Str$(n)) - 1)
If Right(doc.GetTitle, 7) = ".SLDPRT" Or Right(doc.GetTitle, 7) = ".SLDASM" Then
    f.Name = Left(doc.GetTitle, Len(doc.GetTitle) - 7) + num
Else
    f.Name = Left(doc.GetTitle, Len(doc.GetTitle)) + num
'f.Name = Left(Right(doc.GetTitle, 10), 3) + num
'add 3d bounding box
   Set Part = swApp.ActiveDoc
   Set modDocExt = Part.Extension
   boolstatus = modDocExt.SelectByID2(f.Name, "SUBWELDFOLDER", 0, 0, 0, False, 0, Nothing, 0)
   modDocExt.Create3DBoundingBox
                'del Mark and PARTNUMBER
                bRet = f.CustomPropertyManager.Delete(propname7)
                bRet = f.CustomPropertyManager.Delete(propname8)
                'mass
                bRet = f.CustomPropertyManager.Delete(propname1)
                bRet = f.CustomPropertyManager.Add(propname1, proptype, Chr$(34) + "SW-Mass@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34))
                'bRet = f.CustomPropertyManager.Add(propname1, proptype, Chr$(34) + "SW-Mass@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34) + " kg")
                'If f.CustomPropertyManager.Add(propname1, proptype, Chr$(34) + "SW-Mass@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34) + "kg") Then
                'Debug.Print "Property "; propname1; " added to feature "; f.Name
                'End If
                'desc
                'If f.CustomPropertyManager.Add(propname2, proptype, "PLATE") Then
                'Debug.Print "Property "; propname2; " added to feature "; f.Name
                'End If
                'type
                If f.CustomPropertyManager.Add(propname3, proptype, "PL") Then
                Debug.Print "Property "; propname3; " added to feature "; f.Name
                'Plate & Formed Plate stocksize and Length and desc
                If f.CustomPropertyManager.Get(propname10) = "" Then
                   If f.CustomPropertyManager.Get(propname9) = "" Then
                       bRet = f.CustomPropertyManager.Delete(propname4)
                       bRet = f.CustomPropertyManager.Add(propname4, proptype, Chr$(34) + "PL" + "SW-3D-Bounding Box Thickness@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34) + "x" + Chr(34) + "SW-3D-Bounding Box Width@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34))
                       bRet = f.CustomPropertyManager.Delete(propname6)
                       bRet = f.CustomPropertyManager.Add(propname6, proptype, Chr$(34) + "SW-3D-Bounding Box Length@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34))
                       'desc plate
                       bRet = f.CustomPropertyManager.Delete(propname2)
                       bRet = f.CustomPropertyManager.Add(propname2, proptype, "PLATE")
                       'If f.CustomPropertyManager.Add(propname4, proptype, Chr$(34) + "SW-3D-Bounding Box Thickness@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34) + "x" + Chr(34) + "SW-3D-Bounding Box Width@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34)) Then
                       'Debug.Print "Property "; propname4; " added to feature "; f.Name
                       'End If
                   Else
                       bRet = f.CustomPropertyManager.Add(propname4, proptype, Chr$(34) + "PL" + "SW-Sheet Metal Thickness@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34) + "x" + Chr(34) + "SW-Bounding Box Width@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34))
                       bRet = f.CustomPropertyManager.Add(propname6, proptype, Chr$(34) + "SW-Bounding Box Length@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34))
                       'desc formed plate
                       bRet = f.CustomPropertyManager.Add(propname2, proptype, "FORMED PLATE")
                       'If f.CustomPropertyManager.Add(propname4, proptype, Chr$(34) + "SW-Sheet Metal Thickness@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34) + "x" + Chr(34) + "SW-Bounding Box Width@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34)) Then
                       'End If
                Else
                'grade
                If f.CustomPropertyManager.Add(propname5, proptype, Chr$(34) + "SW-Material@@@" + f.Name + "@" + doc.GetTitle + ".SLDPRT" + Chr(34)) Then
                Debug.Print "Property "; propname5; " added to feature "; f.Name
Set f = f.GetNextFeature
Loop
