0 Replies Latest reply on May 22, 2015 5:27 AM by Yong Ning
    InsertBomTable2→How to use Configuration?
    Yong Ning
      retval = View.InsertBomTable2 ( UseAnchorPoint, X, Y, AnchorType, BomType, Configuration, TableTemplate)
      Input:   (BSTR) Configuration    Name of the configuration for this BOM table
      Why follow code
          Configuration =“”
      → Hope
          Configuration = "A2"
      ' Preconditions:
      '       (1) Drawing file is open.
      '       (2) View is selected.
      ' Postconditions: A BOM is inserted at the anchor
      '       point or the specified point, if the drawing
      '       view does not already contain a BOM.
      Option Explicit
      Dim swFeatMgr As SldWorks.FeatureManager
      Dim swView As SldWorks.View
      Dim swBomAnn As IBomTableAnnotation
      Dim swBomFeat As SldWorks.BomFeature
      Dim AnchorType As Long
      Dim BomType As Long
      Dim Configuration As String
      Dim TableTemplate As String
      Dim Names As Variant
      Dim Visible As Variant
      Dim boolstatus As Boolean
      Set swModel = swApp.ActiveDoc
      Set swFeatMgr = swModel.FeatureManager
      ' Select view
      Set swView = swSelMgr.GetSelectedObject6(1, 0)
          AnchorType = SwConst.swBOMConfigurationAnchor_BottomRight
          BomType = SwConst.swBomType_e.swBomType_TopLevelOnly
          Configuration = ""
          TableTemplate = "e:\a.sldbomtbt"
          ' Insert BOM table
          Set swBomAnn = swView.InsertBomTable2(False, 0.4, 0.05, AnchorType, BomType, Configuration, TableTemplate)
          swModel.ClearSelection2 True
          ' Because BOM type is swBomType_TopLevelOnly, then work with BomFeature to get and set configurations
          Set swBomFeat = swBomAnn.BomFeature
          Names = swBomFeat.GetConfigurations(False, Visible)
          Visible(2) = True
          boolstatus = swBomFeat.SetConfigurations(False, Visible, Names)
          'Update FeatureManager design tree
          swFeatMgr.UpdateFeatureTree
      Function A3InsertBom(SwView As View, Xx, Yy, BomPath)
        Dim AnchorType, BomType
          Configuration = ""
          Set swBomAnn = SwView.InsertBomTable2(False, Xx / 1000, Yy / 1000, AnchorType, BomType, Configuration, BomPath)
        Dim SwBomFeat As BomFeature, Names, Visible
          Set SwBomFeat = swBomAnn.BomFeature
          Names = SwBomFeat.GetConfigurations(False, Visible)
          For jj = 0 To UBound(Names)
             If Names(jj) = SwView.ReferencedConfiguration Then
                Visible(jj) = True
                Exit For
          Next jj
          boolstatus = SwBomFeat.SetConfigurations(False, Visible, Names)
      End Function
      Private Sub ll()
         Dim SwApp As SldWorks.SldWorks, SwDraw As DrawingDoc
            Set SwApp = Application.SldWorks
            Set SwDraw = SwApp.ActiveDoc
         Dim SwView As View
            Set SwView = SwDraw.GetFirstView
            Set SwView = SwView.GetNextView
            A3InsertBom SwView, 400, 5, "e:\a.sldbomtbt"
